Bad shaking from rear end
1QuickCoupe
Gillette, WY
I was taking the cruiser to work and the thing started to shake violently. I thought maybe I had a flat tire. I pulled over to check and all the tires were fine. The left rear wheel was hotter than **** though. Would this be a bad bearing, or maybe the caliper hanging up? I didn't do much of an inspection because it was super hot, and I was already late for work. Any ideas? Thanks
CerberuS
300 HP N/A SHO
Granby, QC, Canada
First idea that comes in mind is your LR wheel , is loose , remove cap see if the bolts are sill tightened.
1QuickCoupe
Gillette, WY
That was the one thing that I did check. I have the GEN III chromies on it, so that part was easy. Thanks though:thumb:
AREA 91
PA SHO SHOP
Area 91
Sounds like the classic rear caliper slider pins hanging up. I've seen it too many times.:thumb:
1QuickCoupe
Gillette, WY
Thanks guys, I'll go check it in a bit and post back :thumb:
If it is the slider pins hanging up, how do you remedy the problem?
wood_e
The dude
Ames, IA
Take out the pins, clean them (if its bad use a wire brush) and re grease them. Also, make sure the boots aren't cracked. Your local part store should have pins and boots too if needed.
Hank F.
Portland, Oregon
I recently had an 80% tread Toyo 800 with the same symptoms that turned out to be separating tread. It was not apparent until looking at all 360 degrees of the tire. Good luck...Dave
