bad gas mileage
fuhSHO
Seattle, WA
i got code 14, i dont know what it means though. the car runs perfect except bad gas mileage. what will code 14 cause and how can i fix it?
masho95
got Zex?
Chicopee, MA
Code 14 is a PIP circuit failure. Due to loss of power to the CKP sensor or a failing crankshaft position sensor (CKP). You've had no other problems other than bad gas mileage? What do you consider bad mileage? Do you drive city or highway or both? I've never heard of a CKP sensor causing bad gas mileage. And you'll also usually have other symptoms with a failing sensor.
<small>[ August 01, 2003, 09:27 PM: Message edited by: masho95 ]</small>
