Backglass Question
dantheman68
Kinda Big deal
Pewaukee, Wisconsin
can the backglass (or rear window) be replaced on a genII with an LX or other Taurus SLO from the same years or does it have to be an SHO window?
SolidState
No Mo SHO
Toronto, Ontario, Canada
are you going to try and remove one from a junkyard, or buy new glass?
I need a new rear window, and don't really know what to do. Cost of the glass with installation up here is something like $1400...
rangerj
Brunswick, Ohio
NOTE: SHO and regular Taurus are the same. the Sable may be the same, but check this out if you find a Sable in the salvage yard. A new rear glass for Gen I and II, with the defroster, is about $650 U.S. plus instalation. The plastic molding pieces are available new at a few of the parts web sites. I think I remember seeing it on the Rock Auto web site, but am not sure.
dantheman68
Kinda Big deal
Pewaukee, Wisconsin
well ive done it on other cars, its a pretty simple job you just have to be careful and take your time or your window will crack you can get a donor car, this is probably the cheapest, although it can be hard transporting the glass. there actually is a tool that removes windows that has a sharp blade that slides between the car and window to cut the adhesive material off. you could easily do it yourself, although i dont know much about the plastic trim on the edge... i did it on an older car so it was a screw in chrome piece that was around the edge of the window.
the only thing thats hard is that you need patience or else youll find yourself needing a new window again...
jelloslug
Digital
Greenville, SC
1st gen rear glass is about $200 installed. I had one put in last year by Safelight.
