Back(left) smoking?
youngsho
Kansas City
I just assumed that my valve covers were leaking because i had bad smoke comming from the back of the motor.. so i changed. them put it all back together and i still have SMOKE im so confused because since its all back together i can't tell where its comming from but i swear i can hear something boiling back there and i just see smoke.. if i look under that car it looks as if something is getting down to the y-pipe and being burnt.. the more i rev the car tha more that comes out.. what beside my valve cover gaskets could the oil or whatever it is be comming from back that way.. Im so confused because this is my first sho taurus..
I'm just trying to figure out if i should keep this car and get the tranny yanked out and put in another on i have found that the motor seems doesnt have any problem but the tranny is fried.. or just go ahead and fix this.. if anyone has any idea please help before i take this to a shop and get charged out the :oogle: for something i might not even fix
shoteen95
isn't a teen :D
Dearborn Heights, MI
Are you sure you didn't roll the new gasket when you installed it? Happened to me when I changed gasket. I bought a small telescoping mirror (like they use at the dentist almost) so I could check the length of the gasket after I put it on a second time just to make sure it hadn't rolled off the valve cover. You may also be able to spot what exactly is leaking too if it's not the VC gasket.
projectSHO89
SHOless In St L
Check your rear cam seal.
Run your fingers under the cam position sensor and its housing. If they come back oily, the seal behind the sensor is leaking.
Steve
SASHO91
Zoom Zoom
San Antonio,TX
Steve, if im not mistaken, when the rear cam seal(CID) leaks, it leaks on to the P/S pump, and down onto the subframe... granted some could get to the cat...
but i think the problem lies with the (rolled) Valve cover.
However, i'd be willing to bet that a Cam seal could have been causing some of the previous smoke as well.
youngsho
Kansas City
Where is the Cam Seal? how hard is it to change? Im new to sho's and i havent really found a good place online to show me where the parts are on the motor.. is there any way for me to check this valve cover without taking it completely back apart
Mr95Gl
Mr Tire Iron
Brooklyn, N.Y.
I could almost swear that I've read some where, that oil leaking onto the y-pipe or cat is the rear main seal. . . . . might be mistaken. Good to check though. Good luck! :thumb:
pvsho91
ARLINGTON, TX
I had a very similar problem with oil leaking on to my y pipe and smoking, it turned out to be a cam seal.
shook0002
Philly
I just went through that on mine, First somebody used rtv on the rear valve cover, so I had to scrape all that clean and replace em. Then I ended up replacing my rear cam seal, but the cause was a front crank seal, dripping right down on the front cat causing a nice smoke screen.
Mr95Gl
Mr Tire Iron
Brooklyn, N.Y.
Ah, I see! How bad was the leak? A steady stream, or just drips?
youngsho
Kansas City
im still a lil confused everybody says its a cam seal.. and i looked on that page but i still couldnt find what im looking for.. i figure its the cam seal cause when i took it to a shop they said my powersteering was leaking real bad but its not leaking at all.. thanks for who looked out and told me that it leaked on the power steering box.. but i have no idea where this cam seal thing is at
