Availible shift kits for gen 2 atx
V6&V8SHO
wauconda, IL
Is the only shift kit availible for the gen 2 atx sho the Mr. Shift shift kit which I belive is made by trans go? Cause im curious if there are any other shift kits out there for the gen 2 atx.
stevetatro
Cincinnati, Ohio
You'd better have over 300k miles to be ready for ATX #5. That's rediculous.
Where are you having these rebuilt? Or are you abusing them?
My rebuild (complete with Transgo) has lasted a long, long time. I flush (not drain and fill) the ATF every year. Cost $80, benefits are unmeasureable (is that a word?).
Slo-Sho
It wasn't me!
Crossroads, CNY
Are these places flushing the ATX coolers? There is a thermostatic valve that will remain closed unless the fluid is hot enough to open it. FWIW I've never seen my ATX temp go above 220 although I've never tracked the car, usually it stays around 180. I have removed my bypass valve and am only running the front mount cooler (no radiator cooler).
tracy_s_1993_atx
Plano, Texas
Ford was rebuilding them until the last one...
The last one was built by a performance shop that installed all the latest upgrades...
The SHO now has 107k miles.....
Michael and Tracy
coldsho
Chalkboard SHO
algonquin il
i got a new trans with shift kit fom fps, its ben over a year, and there is no sign of any problems, less u count ripping second apart everytime, and every once in a while third. it was just expensive. but, damn was it a diferance.
SHO#7
Cincinnati
Slo-Sho:
Normally after a car is driven in to the shop by the customer that drove 20 miles to get here, the transmission fluid is of tempature. Also, most flushing machines are equipped with a pressure monitor, that once below a certian level will kick off the flush process. But to answer the question. Yes, we flush the cooler too.
