Chris Briggs
I don't know if this is normal or not but I have noticed when I am using the Climate Control even in the winter that the auxillary fan immediately turns on. It did a little experiment and tried all the fan settings manualy and found that the defrost, high and low, and the actual AC Max setting where the only ones that were kicking on the radiator fan. The vent, and floor fans do not. After reading I see that these same settings that turned on the auxillary fan will also turn on the AC unit when neccesary. The AC however is not engaged as it is 30 degrees out and it will only start (the AC) at 50 or above outside. Is this normal for the auxillary fan to kick on even when cold as some sort of safety measure when possible AC fan settings are made in case of the AC kicking on and it's just not smart enough to know that it's cold or is it defective?
Thanks
CB
Thanks
CB
