sho_bc
Dragonboater
figured i'd start a thread where people can post their allignemnts and thoughts/experiences on different set-ups.
based on Fred's post here, i was thinking of going with a street/auto-x set up of the following:
Front:
Camber -2.25 deg
Toe 1/16" toe out
Rear:
Camber -2.25 deg
Toe zero
is it fine that the front and rear camber are the same? or should i have a little less negative camber in the rear? any thoughts on caster angles? i'm at 4.6 and 4.8 degrees on R and L respectively (not sure why they'd be different....)
Front:
Camber -2.25 deg
Toe 1/16" toe out
Rear:
Camber -2.25 deg
Toe zero
