Auto Clutch Adjuster , How To Adjust Manually?
Black Stallion
Lehighton, Pennsylvania
It is driving me crazy. I only have 4th and 5th gear. I have tried to pull up on the clutch pedal, but nothing. Still the same. So how do I do it manually?
TYSHO
Earth
Push up the clutch pedal, then push the blue quadrant downward [I believe it's downward, if not then it's upward] and release the upward pressure on the clutch pedal so it can lock on the quadrant. Keep doing it until you find your sweet spot. However, if you do this, then later hear some clicking from the pedal and get your symptoms back, you most likely have a bad quadrant. I had this problem and the little spring deal on the backside was broke.
Black Stallion
So does the car need to be on and whats the blue quadrant? Wheres that at?
I will give it a shot tomarrow. Thats what one guy told me that it is a spring. Would it cost alot for a mechanic to fix it?
Thanks.
SASHO91
Zoom Zoom
San Antonio,TX
the blue quadrent is up under the dash, on top of the clutch pedal.
just as TySHO (brian) explained, you need to pull the pedal up, (that in itself should reset it) and get a long screwdriver to push the quadrent towards the engine bay/firewall. you need only to move it maybe a 1/8'' or so, maybe a 1/4'' if its all out of whack.
Ford carries new quadrent kits.
its called quad&pawl kit. P# E7FZ-7L583-A I cant recall the price, but its not more than like 30 bucks or so....
SASHO91
Zoom Zoom
San Antonio,TX
its inbetween the pedal "walls" up on top of the pedal... its like a baby blue.
its hard to see without some light in there, but once you find it is easy to find again.
Black Stallion
hey this black stallions brother....i just kinda fooled around and pushed around on a few things then started it up and tried to jam it in gear and i have first and second...i didnt use to. think its good now?
Black Stallion
Hmm has a brand new clutch, but im gonna just take it to a mechanic, get it done right (well i hope), instead of me doin a half ass job. Thanks alot for the input I really appreciate it.
Noblesville, IN
Could you please post a picture? I spent a long time looking at it and kinda messing around with it, but I didn't get anywhere but a sore back from being at an awkward angle. Does anything have to be loosened at all? Bolts? 'Cause my pedal doesn't go up too far from it's resting position.
TYSHO
Earth
It bearly takes anything to make the cable release tension. If you have the pedal pushed up as much as it can go, that's good and you don't need to hold it with 500 pounds of pressure, just keep it in place.
Here's a picture I just took like 5 minutes ago. The part is in the black circle and is blue:
Noblesville, IN
well, I got it to work, but my SHO still does the same thing. It's kinda difficult to get it into some gears. I always have to be careful, otherwise it'll grind. Even though it's kinda rednecked and cheap, I'm thinking about trying to put washers on the cable just after the fork on the transmission, to kinda pick up on what seems to be a little slack that the clutch adjustment won't catch. Any input?
Black Stallion
Well my car is goin into the shop Thursday, hope they fix the problem. Im not even drving my car right now. The one time I tried to put it into 5th, it went in but man did it ever grind, it was so loud, I dont want to damage anything.
