ATX Y-Pipe Gasket
BenBrausen
Minneapolis, MN USA
With the super cold (-20) weather we've been havin' latley, I've noticed that some exhaust is comin' out from under my car around where the flex pipe is. Anyone know where I can get the gasket for it? I've done a search and found tons of numbers for the MTX but can't find anything on the ATX. I assume it's different. Any help would be great. :D
SHOtimer
#2910
Santa Clarita, Ca
I got mine at the dealer. If I remember it was only 6-8$. Takes a few minutes to change..depends on how rusted the two bolts are. FPN should be able to get you one also.
Doug
masho95
got Zex?
Chicopee, MA
BenBrausen:
Do you have a flex pipe and a donut gasket after that? I'm confused... usually a flex pipe is used to eliminate the donut gasket leaks.
Yamaha V6
SHO Enthusiast
Rhode Island
It's available outside of the dealer (have heard of people getting them aftermarket), but I've always gotten mine for the ATX & MTX from Ford.
SHOtimer
#2910
Santa Clarita, Ca
It is a flat metal gasket with lead on the outside. Similar in material make up to the EGR to Plenium gasket. So, no donut gasket. Yes, at least mine had a flex pipe.
Doug
