kconnor
My 1993 ATX developed a transmission pan gasket leak. Over the winter I parked it in the garage put a drip pan under it. Nearly all the fluid dripped out during that time. Springtime I filled the transmission with fluid in order to move it decided to drive it around the block. The transmission would not shift out of first.
I’ve since fixed the leak made sure it was topped it off with fluid and problem persists. Tranny shifted fine before I parked it. No problems at all.
I’m wondering if the problem is in the valve body? It does not slip in first gear it just won’t up shift.
