atx trans question
Irish Pride
Irish Inside
MusicCityUSA
Yes, it will work. Starting in 93 all ATX Taurus got the AX4S Trans.
no, it will not work. not correctly. the final drive ratio is different and it will not lock up the torque converter and it will set many codes about incorrect ratios.
also, the 3.8 bell housing is completely different and it will not even bolt up.
crystizel
