I may be missing something here, but how do you maintain the tension on the belt that the tensioner tool establishes after the tool is removed? The only thing that applies pressure to the tensioner pulley's pivot arm is the pressure from the gas piston. That is the piston's only job - to apply the correct tension to the timing belt throughout its life. The tensioner tool is not required. As long as you don't loosen the screw that holds the pulley to the pivot arm, there is nothing to adjust.
After the gas piston is removed from the engine, you compress it with a C-clamp or vise and insert a 1/16" pin or drill bit through the holes to hold the piston shaft retracted. After the belt and the tensioner are reinstalled, all you have to do is remove the pin to let the gas piston apply pressure to the pivot arm to properly tension the belt.
Scott
1991, 254K miles, glass hood, police grill, SVO shifter, Catz fogs,
Eibach/Tokico/polyurethane, SHO Shop front & rear strut braces,
6 disc CD, Class II hitch, Silver award at SHOklahoma Car Show
[This message has been edited by sdpatt (edited 01-19-2002).]
