ATX timing belt hydraulic tensioner help?
Spring Hill, FL
http://www.shotimes.com/php-bin/mod...le=article&sid=65&mode=thread&order=0&thold=0
Step 17, it just doesn't make any sense to me, I removed the two bolts but the tensioner doesn't seem to move out of its place, is it connected to the pulley or what? Do I have to pull the pulley back and then pull the hydraulic tensioner out? Does it just dangle there? I'm totally stumped right now, I just today got the c-clamp I needed and now I can't do anything, so this bites :mad: Well, thanks for any help, I really need it, I can get this waterpump and crap finished now :oops:
Spring Hill, FL
Awesome! Thanks! :biggrin: As lacking as those directions are sometimes for ATXs they had it right, woohoo :boink:
Tiny allen wrench now in the pin hole and belt is nice and loose, awesome, should be a piece of cake from here on! :biggrin: Crap.. I think I might have jinxed it :doh:
Spring Hill, FL
When you take the allen wrench back out does it extend again eventually? Is it powered by oil pressure or something? I'm really curious now, and worried, I don't think it went out, I just pulled the allen wrench and it came out super easy :shrug:
Yamaha V6
SHO Enthusiast
Rhode Island
If the piston isn't unloading by itself, it's either blown, or you bent the piston when compressing in a bench vise / similar. If you get stuck, I have a couple ready to ship, email at [email protected] (again, if you get stuck).
Off Road SHO
Moderator
The piston is driven by spring pressure only. Two of them actually. If you can push it in easily, it's toast....yeah toast.
Tom
Racer X
SHO Pilot, Retired
Connecticut
Uh oh. :hpoop:
I don't know about the 3.2L SHO, but most other cars I've done wtih this setup, the tensioner piston is spring loaded.
Fred, you wanna step in here?
Spring Hill, FL
Well I did it like in the pictures.. damn.. I guess I broke something, but if it was going to I guess it was going to. They said it was hydraulic, I figured it was oil pressure or something. How much do they run? How the heck do you put them in?
Spring Hill, FL
Oh, and it was really hard to push down, like it should've been able to, it just didn't extend, so I dunno whats wrong with it, this is :bs: though :frown:
Spring Hill, FL
Well, I consulted my dad about it, he said when I pulled the allen wrench it went up and tensioned the belt again, I'm going to check it tomorrow, when there's hopefully not a 103 F heat index :bonk:
dan.delargy
