ATX Pressure Test
Winterhawk
1993 SHO ATX
Independence, Missouri
Anybody done a pressure test to their AX4S? There are 3 pressure ports with one being the EPS. I'm thinking about trying it before I take it back to Certified for replacement? I found some for $105.00 delivered.
http://www.tooltopia.com/gsi-6750.a...m=cse&utm_term=GSI6750&utm_campaign=nextag_r1
Winterhawk
1993 SHO ATX
The last couple of weeks I've been trying to research raising the pressure on my ATX without using the Tweecer and or the LPM. I've been told by Certified Transmission that they will put in a line riser for free. The Transmission now has 6,000 miles on it. The line riser is a resistor of some sort. I did find that reducing the current to the EPC will cause a pressure rise. Does anybody know about what size resistor is needed? I've been hearing anything from a 5 ohm to 50 ohm resistor. Has anyone else tried this? I do have the D4U1 PCM installed. It still isn't wanting to hit 2nd gear very well under power.
On some GM transmission I've seen the resistor setup on a very nice factory style plug in to the transmission.
Cheap Electronic Shift Improver for Automatic Transmissions
by www.FRKNLO.com
Purpose
Instead of buying a electronic shift improver you can make your own using
resistors.
How it Works
Heres a quote from the GM Service Manual for a 4L60E automatic
transmission.
The transmission pressure control solenoid (PCS) is an electronic
pressure regulator that controls pressure based on the current flow through
gh its coil winding. The magnetic field produced by the coil moves the solenoids internal valve which varies pressure to the pressure
regulator valve.
Thus, the PCM controls the pressure control solenoid by commanding
current between 0.1 and 1.1 amps. This changes the duty cycle of the
solenoid, which can range between 5% and 95% (typically less than 60%).
High amperage (1.1 amps) corresponds to minimum line pressure,
and low amperage(0.1 amp) corresponds to maximum line pressure (if
the solenoid loses power, the transmission defaults to maximum line
pressure).
The PCM commands the line pressure values, using inputs such as
engine speed and throttle position sensor voltage. The pressure
control solenoid takes the place of the throttle valve or the vacuumed
tor that was used on past model transmissions
what the electronic shift improver controls is line pressure by varying the amount
of amperage going to the PCS. The way this is done is by shunting a resistor to
ground (parallel resistor to solenoid). What occurs is more amperage go through
the resistor and less to the PCS (solenoid), in effect bring the line pressure up
which corresponds to firmer shifting..... My brother and I tried it and it worked
by using a simple passive element, a resistor.
Materials
1. Various resistors ranging from 2−3 ohms to 100 ohms. The lower the
resistor value => firmer shifting.
2. wires; same gage as computer wire. Maybe 14−18 gage.
3. 2 splices; same gage as computer wire.
4. male/female connectors (to allow changing various resistors)
Skills Required
Basic understanding of electrical circuits; mechanically−clined individual.
www.FRKNLO.com
www.FRKNLO.com
METHOD
WARNING: We did not do any long−term testing and thus we won’t be reliable for a
ny shit that goes wrong in the long run. There’s also more debate on the wear
and tear of the clutch due to the high line pressure for a firmer shift. From the
numerous debates, the best way to increase shifting performance is by upgrading
the valve body, not electronically. Upgrades via valve body is available from
b&m, jet performance and transgo).
1.0 COMPUTER AND TRANSMISSION INTERFACE
1.1 located on the passenger side of the engine bay; mounted directly to
the inner fender wheels. Before proceeding further, detach the
negative (−) wire from the truck’s 12V battery.
1.2 locate the EPC Solenoid Ground & EPC Solenoid Positive wires.
check out www.transonline.com for specific information for your year
and model of transmission.
WARNING: proceed with caution when working under a truck and near
exhaust piping or other hot sources.
Another way to find the wires is to locate the two wires that is
directly connected to the automatic transmissions; then find the same
colored wires at the computer’s output wires.
NOTE: check continuity to ensure the correct wires.
2.0
SHUNT RESISTOR(S)
2.1 Splice the two EPC solenoid ground / positive wires using the splice
2.2 Attach resistor(S). Check paragraph 3.0 for fine tuning.
2.3 Re−attach negative wire to battery.
2.4 TEST TRUCK in a safe manner.
3.0
FINE TUNING
3.1 Low resistance (1 − 50 ohms) => firmer shifting; race setting
high resistance (50+ ohms) => stage 1, 2 setting
3.2 Firmer Shifting with existing resistor: Add resistors in PARALLEL.
For example, connect 1 and 3 together, and 2 and 4 together. this
lowers the resistance of the resistors:
1 −−−−WWWW−−−−−− 2
3 −−−−WWWW−−−−−− 4
3.3 de−firmer shifting with existing resistor: add resistors in SERIES.
For example, connect 2 and 3.
1 −−−−−−−WWWW−−−−−−2 −−− 3 −−−−−WWWW−−−−−− 4
Winterhawk
1993 SHO ATX
Before I posted this I searched the forum and found your link. The problem is that I get this error.
Winterhawk, you do not have permission to access this page. This could be due to one of several reasons:
Your user account may not have sufficient privileges to access this page. Are you trying to edit someone else's post, access administrative features or some other privileged system?
If you are trying to post, the administrator may have disabled your account, or it may be awaiting activation.
I did the math tonight. Attaching a 50 ohm resistor in parallel on the yellow/white wire to the EPC should make it at 240ma or .24amps if the line is at 12 volts. Thinking about a dial variable resistor that I can adjust to where it feels the best. I need my gages first to see if it is at factory specs first at wide open throttle. Then tweak it and look at the pressures. As long as I stay at max for the EPC at wide open throttle it should handle the pressure. Any feedback is appreciated and I wish the link would open. Apparently Shosource.com is out of business as the site does not work.
:braincramp:
projectSHO89
SHOless In St L
The problem with the riser mod is that the EPC solenoid in the AX4S is a PWM solenoid rather than a variable current solenoid as is the GM example cited in the article you posted. Just changing the current through the solenoid will have effects other than what is desired. Placing a resistor in shunt across the solenoid is even worse.
Among all the chatter a few years back about this mod, I can't recall hearing from anyone who did it and reported their results.
The dead link is due to a forum crash a few years back. A number of posts were lost.
This thread should be titled... "How can I blow up my ATX faster"
