ATTN: Brian
1fastsho
Athens Ga
Hey Brian Please call the shop one more time. Thanks. 770-725-4262
Shawn Pasley
Innovative Performance Technologies
770-725-4262
www.iptech.tv
92 SHO red/grey
3.2L Lowered compression(9:1)
stageII cams, Ported/Polished heads,Ported/polished Intake manifold(runners, endtanks, and behind the throttle body), big bore butterflies,80mm maf, LPM,equal length Long Tube Headers and custom Y pipe, Dynomax cat-back, Koni/coil-over suspension, poly-bushings everywhere,26mm Front sway bar, 28mm rear sway bar, solid subframe bushings,subframe connectors, tubular aluminum adjustable rear control arms,shortened shifter,235/45/17 comp T/A ZR's on TSW VX-1's. 15 lbs of boost here I come!
