ATP Turbo upgrade help
Ryan Selcer
Colorado
See it's the responses like this and this
If it's not the information you need then don't respond to it like a **** or even better just ignore it.
Dude your being a crybaby.
You came in and spouted off info that was not asked for and in no way helpful to the question that was asked.
I kindly responded and let you know that it was not what i was looking for but thanks.
YOU decided to go cry about that and literally throw a tantrum through your next few responses.
As YOU just said except this makes alot more sense. If I didn't ask for the information, you should have just not offered it and cluttered the space.
Ok, next dumb question... are our stock turbos capable of producing more boost than the wastegate can flow? and if so what kind of boost pressure would that be? obviously nobody is dumb enough to try this but I'm curious.
Lee could probably drop more technical knowledge about his.
I have seen stock turbos SHO's run 19+ psi with all the support mods. However at that boost level they are out of the compressor efficient zone. Mr. Banks would calls it "the turbo is out to lunch". That is why the GH Turbos or the APT Turbo upgrades are so good.
Lincoln Ne
On our turbos with impellers the size of a half dollar, definitely no way to exceed the wastegates. Larger turbos with no backpressure, sure you can boost creep as the last of backpressure can prevent the wastegates from doing their job and the turbos will overboost. But not the case here so carry on...
BOOST CREEP, i knew there was a name for it, just couldnt think of it. Only reason i wondered is because of the issues Cleetus McFarland had with Leroy when he put on the second turbo. Again wasn't sure if it was possible on our car but thought id ask.
Ryan Selcer
Colorado
I was reading about this, it has to do with heat as well, most turbos over a certain psi have too much heat in them and that causes the efficiency to plummet
FiveLeeter918
Ortiz Performance Sales
Tulsa, OK
Boost is like age, it's just a number that causes a little restriction in your life. Feeling awkward now?
StealBlueSho
NA
Not just heat but rpms too... according to the tech specs these turbos are not supposed to spin over 200k rpms. Though the two tend to go hand in hand...
Matt Robinson at gearhead did a whole mapping on the stockers... they are pretty maxed out from the factory if you live in Denver...
They also start cavitating.
Ryan Selcer
Colorado
Well luis and lee say it looks like the wastegates are maxing out and dropping the boost. You think its just that they're maxed out with the pressure difference up here?
As in causing low pressure pockets that **** up the airflow? That'll cause it to wobble and come apart right?
Low and High pressure pockets in the airflow from the compressor itself.
Ryan Selcer
Colorado
Probably got a big ol boost leak somewhere you overlooked
Hmm, I guess I could try to look into it more. I put a vacuum on the wastegate lines and they were good. I do hear a whistling but it seemed to start after I had the airbox off this weekend for the Tranny flush, I thought I just didnt get it all the way back in in the front
