atf fluid color
mike25
92 sho
south carolina
i checked the fluid in my mtx today, it was full but the color of the fluid was like a brownish grayish color with a slight red tint to it, is that normal i have not ghanged fluid in it in about 2-3 years.
lowc
aka vapah lock
Quincy, massachusettes
no regular clean trany fluid should be reddish pink and it will not stink. i dont think you can get all of it out with out tapping a drain plug into the bottom of it or pulling it out and apart
jmpSHO2nd
Massachusetts
If you drop the pan to change the filter you will not even get half the fluid out. You will have to bring it to a shop to have a cmplete transmission flush done to remove all the old burnt fluid.
TimboSHO
Intermediate
Wyoming, MI
His sig says he has a 92, which makes it an MTX. The only way to completely exchange fluid without removing the trans is to drill, tap and plug a hole in the bottom.
And BTW, you don't need to take it to a shop to have an ATX transmission flush done. Remove return line from trans (i forget which one it is) and put in 5 gallon bucket. Start car and keep adding fluid as fast as it comes out. Reinstall line and top off.
jmpSHO2nd
Massachusetts
I didn't realize it was an MTX, I am just too tired and didn't read his post in detail I guess. If you do a transmission flush like you said it can get a little messy.
mike25
92 sho
south carolina
there's no metal shaving's or anthing like that in the fluid and it smell's normal to me just has a brownish red color to it.
all atf stinks, especially when new. that is one of the ways you tell it from motor oil, along with the red color.
a brownish grayish reddish color sounds about right for used atf in a mtx. Its going to get dirty from the bearings, syncro wear, etc. that is just how it works.
normally, you only need to change that around every 100k miles, so I wouldn't worry about it.
mike25
92 sho
south carolina
Yeah I opened a new quart today and it smelled just like the old fluid just wasn't sure about the color.The fluid i know is old when i changed it about two years ago I only got a quart or a little over out.ill drain it all next week when i replace the clutch.
lowc
aka vapah lock
yea i know it all stinks probly shoulda been more specific towards the burnt stink of it, and i wouldnt be worried about the trans exspecialy since there is no metal in thier
itwonder
VA
Install MTX drain plug, if you don't already have one. Drain whatever fluid is in there, and pour through a quart of cheap ATX fluid to wash the bottom out. Refill with Mobil 1 ATX.
thatSHOguy101
