assembling earls SS lines
1slickRED89
Guest
Toledo Ohio
I would like to put new ends on my prexisitng earls hyperfirm lines. i have the 'right-sized' earl's line-to-pipe threaded fitting(in a 90 degree shape, to imitate a bangos'). i bought the lines and fittings at the same time when i stopped jegs last summer.
if anyone has any tips or even small things to look out for, please post them. earl's website 'how-to' really wasn't that helpful because there are no pictures. Thanks, Corey
Yamaha V6
SHO Enthusiast
Rhode Island
Corey, I just installed my Earl's lines for my 95, and it was a snap - simple replacement for the existing lines. I haven't seen the Gen 1 kit (is there a kit or are you retro-fitting?).
Good luck!
1slickRED89
Guest
Toledo Ohio
oh, I agree, they fit great. i'm sure you are enjoying your set.
what i'm doing is fitting calipers that require a pipe-threaded connection, so i want to modify my exisitng lines with a new end. i wanted to see if anyone has made up these lines before had some tips. thanks for the reply, Corey
Mr Anonymous
Tire Wall
Just my $.02, but I would never feel comfortable futzing around with a brake hose like that -- I think you'd be better off trying to find the correct hoses or see about having them custom made.
Yamaha V6
SHO Enthusiast
Rhode Island
Are we talking dual piston PBR's perhaps? I saw Kirk Doucette re-fitting & re-flaring his Gen 3 lines to allow the use of the Cobra calipers.
1slickRED89
Guest
Toledo Ohio
i don't either, but there is somthing about hop-ups that are worth it. keep in mind, done properly, these type of connections are stronger, safer and better that any kind of factory made hose. the reason i posted was so that i could get imput and not repeat others mistakes, and to build on their knowledge.
i belive the cobra calipers use a OEM bango style connection, but then, i've never seen those either. the aluminum calipers i have have a inlet that uses a 5/16 pipe thead. email me if you want more info about the hardware spec. thanks guys, Corey
