are 3.0 and 3.2 gen 2 starters the same?
Mr Anonymous
Tire Wall
Yup, Lester 3230. Some had different drives from the factory, but all new ones will have a 12-tooth drive.
Shoaz
Studly dood
Scottsdale, AZ
There are 10-tooth and 12-tooth versions, but both the 10 and 12-tooth starters fit, they're all compatible. The gear offsets are slightly different to compensate for gear sizes so that either lines up with the ring gear properly. ATX and MTX are interchangeable, etc., etc.
The only problems are with GenIs that have the big **** starters with the separate solenoid...but GenIIs are all interchangeable.
TheKrazyRaven
4 8 15 16 23 42
Lawrence Massachusetts
good :thumb:
SHOTIME had one from a 3.2 and wasent sure it would work w/ a 3.0
i'll have a running SHO agian this weekend
