rlw001
I am planning on installing a rebuilt ATX tranny this weekend. The tranny already has the TransGo shift kit installed. Is there anything tricky about this project? I have replaced an MTX trans before by myself and was planning on dropping the subframe to replace the tranny. Any tricks or things I should look out for? How much fluid do you put in the TQ before installing? I will be replacing the rear main seal, carrier gasket, oil pan gasket, gen III sfbs, and rod bearings-maybe. Thanks.
