Anyone w/Autozone starters for Gen II SHO's (mtx)?
CTOESHO
DeKalb, IL, USA
Did any of you guys have problems with grinding during startup with these starters? It was brought to my attention that some of these aftermarket starters don't line up properly with the flywheel. Thanks.
Mike
93mtx
Sam
Fredericksburg, VA
I have a Duralast (DL3295S) that I got from AutoZone in June 2001. It bolted in fine (93mtx) w/o shims and has worked perfectly.
CTOESHO
DeKalb, IL, USA
Well, I'm pretty sure thats the starter that I have in my 93mtx right now too. That sucks, I was hoping it was different so that I knew what that grinding sound was. Maybe my gear is different from yours, and thats why I'm having problems.
Mike
93mtx
LIZARDKING
Arkansas
I used to P/T at AZ. Not content to be a minimum wage flunky, I tried to be a knowledgable minimum wage flunky. AZ sells two types of starters, rebuilt (1 yr warrenty), and remanufactured (lifetime warrenty). The rebuilts are cleaned and bench tested, only defective parts are replaced. The remans are stripped and only the case is reused.
I'm guessing that if you are getting a grinding noise, then you need to shim the starter. I think it is unlikely that the case is the problem. Have you ever surfaced the flywheel? If so, you should have shimmed it however much you took off. I would at least pop it off and look at the teeth, don't want to ruin your flywheel.
CTOESHO
DeKalb, IL, USA
The starter that I got at Autozone was the remanufactured one, not the rebuilt one. In my case, do you think it is more likely that they screwed up the gearing, or less? Thanks.
Mike
93mtx
LIZARDKING
Arkansas
The grinding is probley caused by the starter teeth not properly engaging the flywheel teeth. I would drop the starter and check. If you have any doubts return the starter and get another one. PITA is replace/resurface a flywheel! Also make sure that your flywheel bolts are not backing out. That happens once in a while.
S
SHO bulley
Guest
I work at autozone. If your having any kind of probs tell them. Customer service is our #1 goal! LOL, j/k, but seriously, tell them and they'll probably get you another...
1991 SHO PLUS,SHOshop K&N cold air snorkel, SHOshop LPM, SHOshop Cat back with edelbrock mufflers, Pirelli P6000 Sport velace, 8 speaker JBL system,LONG WISH LIST:
73mm Vortech MAF, Y pipe w/catz, underdrive pullies, paint job and chromed slicers. "5 liter eater"
shobroooo
