JRA2000TL
The Complainer
Just curious. I know some of us use it in our engines. I'm sure the internals of my 89's MTX are well worn at 256k. Right after I bought the car I changed the fluid with Valvoline MaxLife ATF. It doesn't grind nearly as bad as the day I bought it now that I'm putting more miles on it with the new fluid.
I have found that if I press the clutch and don't wait 3 sec. to shift into R or 2nd, that it will occasionally grind....reverse I'd consider normal; 2nd, not so much maybe. I know the shifters came with a tag on them when the cars were brand new and the instructions specifically state to wait 3 seconds before shifting from N to R. When I do this, I'm ok. When I first got the car, I thought the trans was totally shot. It was grinding horribly.Dan (SHOhopeful) witnessed this when we took it for a test drive. The ATF seems to have greatly improved it so far.
I guess it's the blocking rings? that wear out over time in these cars. Guess my ultimate goal of my long-drawn out post is that if any have used it in their MTX or ATX, how'd it work? Did shifting improve or get smoother? Supposedly you can also use this in your power steering. It's simply a detergent with lanolin as a cleaning agent.
