Any problem turning engine backwards?
roswell998
Atlanta, Georgia
Specifically, when measuring valve shim clearance is there any problem with turning the engine backwards as well as forward?
This is an automatic, so to rotate it I plan on using a ratchet and socket on the crank shaft bolt which will be torqued to spec and not loose. The spark plugs will be loosened to release compression.
