Any Ideas???
dtp-sho
Tampa, FL
My engine is stuttering while i'm at a redlight. My oil light flickers on the dash when this happens. I have a 1994 ATX with 101,769 miles.Can someone tell me what my problem could be?
Also i'm changing the oil today. What do you guys suggest is the best way to get to that friggin' oil filter. :madflame:
NiNeTy Fo SHO
No-mo-SHO Man
Troy, Ohio
1) pull the codes....it could be a lot of things...my first GUESS would be IAB...
2) from under the car...I never have any problems getting to it.... :thumb:
sideSHO
East TN
As said above,check(clean) IAC valve.
Clean the MAF sensor.
Have you done a 60K?
Search for these topics,lots of info to be had.
The oil filter should be pretty easy to get to.
Do you have an oil filter wrench?
If your oil light is flickering that means the RPM is low and there is not enough oil pressure at that RPM.
Put the car in N at red lights to help with RPM untill you get your idle figured out.
