I have a 95 SHO ATX and somewhere I'm leaking antifreeze and its burning off the engine block. When I stop, my car makes a huge cloud of smoke and it looks like its on fire. Not only is this embarrassing, but it also makes me go through a gallon of antifreeze every 2-3 days.
I checked the main hoses on the radiator (top and bottom) as well as their respective destinations (engine block for top, water pump for the bottom). I'm not sure of the location of the freeze plugs on 3.2L SHOs, so I havent checked those thoroughly, but I dont think they are the problem.
I got under my car while it was running and radiator fluid was leaking out the bottom. It was coming off the exhaust so I followed it upward. From under the car, the right side (passenger side) of the engine near the pullys is saturated with antifreeze. The left side of the engine block is dry, top and bottom.
I followed the wetness located on the engine and traced the last known fluids to just below the water pump. This makes me think I might have a water pump leak, but it seems as though the water pump is encased within part of the engine block. I'm not saying its part of the engine, but it looks like itll be **** to get to.
Does anyone have any suggestions or have any ideas on how hard it is to replace your own water pump? I've done all the amateur work on my car myself (rotor swaps, brake jobs, suspension, starters, alternators, etc.) but i've never replaced a water pump.
Thanks in advance for any help and I've also included some pictures. The area with the light is where all of the saturation is, and the pictures were taken from under the passenger front wheel well. I believe the pully in the picture is my drive train pully with the water pump pully located directly above it, but ill have to check the diagram again. I dont recall off the top of my head.
(pictures taken with cell phone sorry for quality)
