SuperG
I am replacing my antenna mast with the GM Metra replacement for the 'vette on my SHO. However, I am having 2 problems.
First of all, the installation was easy, although a bit confusing. There is a sleeve that can slide off the antenna mast and appears to be too big to fit into the tube in the motor housing. In addition to this, I put the antenna and nylon string in, then replaced the chrome nut...but the problem here again is that the lip on the bottom, largest antenna section is too large to go down into the tube...this results in the antenna operating fine, but stopping short of retracting all the way. The whole (now retracted) antenna remains above the fender, when before, the top of the antenna went down until it was even with the fender.
Second, with the antenna wire now plugged in, I still do not get reception...any ideas here? Everything seems to be clean enough...
Thanks for the help! By the way, here is the antenna I bought...
