newshofan
So I know this is well discused. I but I wanted to get some feedback or info on putting a better tranny cooler in. I know the most common solution is to put the gen2 cooler on. Is it a pretty simple bolt on or is there more modification that needs to be done? I know there are also other options out there but cost wise would the gen2 cooler still be the best option.
Im asking these questions because im under the impression my tranny is running awful hot when I use hard throttle like around 80 or 90 and with it being in the high 90s here im sure the tranny is burning up... and with the sunroof tilted you can smell what seems to be burnt tranny fluid. Fluid level is great last I checked
