Another turbo question.
Phoenix
SHOHOLIC
QC , Canada
Ok in my turbo shogun I installed some one-way valves for the brake booster and butterfly actuator and the BOV , so the boost dont blow in these things.
Do I need another one way valve for the stock fuel regulator?
and
Im on stock ford plugs , do I need colder plugs at this point? (4-5 psi)?
ycode90
Out in front!
No the stock reg will be fine under pressure . The BOV dosen't require one either . The only real worry wth boost on a SHO (besides the obvious ) is the PCV system . Everyone has their own way.
yamahaSHO
E85 whore
Arkansas
BOV should not have a check valve on it. If it did, they would build them in. The boost helps keep them shut so they do not leak. Putting a check valve in could also lead to it not sealing correctly as it would only allow the diaphragm to breath one way.
Braker booster... Most have a check valve built into them. Doesn't hurt, but I've read people having falures with additional valves leading to no assisted braking.
Fuel pressure regulator... You WANT boost to be seen on the port so it can rise to a 1:1 ratio based on boost. You may want to sit down and read a bit more on boost.
Butterflies... Never had an issue. The canister in the back only flows one way.
PCV... Vent to atmosphere or turbo inlet, preferably with a catch can or AOS.
Phoenix
SHOHOLIC
QC , Canada
PCV is already catch canned.
For the BOV , its a stock plastic BOV off a dodge shadow turbo , and it had a check valve before it (on the small line).
So now I donno what to do :)
What about the plugs?
91PDXmocha
Portland , Oregon
I say ditch the check valves . I ran low boost on stock plugs for a while with no issues but soon changed them out for autolite 3923's .
yamahaSHO
E85 whore
Arkansas
Ah, you're using a cheap Bosch BOV, huh? I highly recommend something better.
ycode90
Out in front!
Ewww , yea get a better BOV 4-5psi on a SHO is a lot of air . That small plastic valve probly aint gonna cut it .I've got a cheap-o CXRacing one off e-bay . It's been great .
Sho Amo
SmkTyresntDrugs
Olney, Md
i recommend not using the autolite 2923. I have had nothing but issues. Other people have had good luck with the autolite racing plug.
