pete c
just put new pads/rotors on the rears. The passenger side was down to the rivets. The apparent culprit was sticky pins due to a torn boot. I replaced that sides pins and lubed both sides. I losened the adjuster under the rockerpanel. Now the driver side drags a little, enough to heat the wheel up a bit. From what I can tell that adjuster only helps the passenger side. Is there another adjuster hiding somewhere? Is it adjustable at the brake lever.
