JRA2000TL
The Complainer
After searching, I figure I'd post to get some input. I was looking at the SHOPhoenixproject website for the front and top 60k guides. They do look pretty intimidating. I thought about getting them done since I have a valve sounding noise in the top end. While our mechanic friend is in there, I thought it'd be best to get him to just do the 60k, which he may have to anyway if the sound isn't an obvious tensioner or something.
My question is...do I have to do the front 60k as well? The previous owner supposedly checked the timing and it's dead nuts. I'm sure we'll double check this as part of diagnosing the odd engine sound. The water pump is new. I was told it was replaced recently, and it has been (it's shiny brand new). The car of course does not have a stalling CPS problem either, and does not appear to be leaking oil. I read a post by SHObill, who has a very good reputation, and he told one member that if he's not having water pump or CPS problems to not worry with the front. Is this ok? I loosened the timing cover and pried it apart to look at the belt, and it looks good.
I'm already buying vc gaskets and an intake manifold gasket. If I throw in plugs and wires, that's a top 60k since he will be checking the valves while he's in there. I'd like to save some money and use it toward fixing other things on the car that need attention like the power steering and exhaust.
