Am I correct in assuming...
SASHO91
Zoom Zoom
San Antonio,TX
Ditto.
I had mine drilled into the MAF(after the sensor-75mm) but the threads stripped out, cause I had the wrong tap. So, I just drilled a small hole, about a 1/3 of the nozzles size, in the intake tube. Hit it with a light coat of RTV, just incase and haven't had anyproblems since; that was 3 bottles ago.
But it is possible to plumb it into the TB, you just have to modify the intake hose alittle.
