This is not a direct answer to your question, but it's related....
There is a champher(sp?) in the large washer that might not be present on the AL SFBs. If it's not there, I would put one there. Just round off the inside corner all the way around(where the shoulder of the bolt will sit. You can use a file or something, but you don't want a sharp edge on the bushing's hole.
I read this on ARPs website years ago. When you buy their head bolt kits, the washers that come in the kit have champhers (rounded corners) cut into the edge of the hole on one side. As I recall, the directions for their headbolt kits tell you all about it...and to install the washer, "champher up".
A champher on a big washer like that serves a purpose. It's there so that the corner of the washer's hole will not cut into the bolt where it meets the head, and weaken it. This can happen from lateral force, or during torquing.
If you use a washer(don't use the recall washers), make sure the sharp edge is digging into the aluminum, not your bolt head.
