'92 MTX, Just replaced my alternator and began having weird problems with the ECC head unit cutting completely out at higher engine speds (around 3,000 rpm) and then coming back on when I slow down (around 2,500 rpm). Does this even in neutral. Thought I broke a wire and was getting intermiitent contact, but I think the voltage regulator in the new alternator is bad?
I get about 12.6 volts at the battery with the engine off. Battery was tested and is good. Engine at idle speeds I get about 14.5 volts, however as I increase rpm the voltage keeps climbing and got up to 18.5 volts at 4,000 rpm. Didn't want to go higher in neutral.
Is this a sign of a bad voltage regulator or alternator?
