Alignment Question.
michaelcz
TT SHO
Albuquerque, NM
Do I need to take my SHO to a person that knows how to work on them, or is it not that difficult? How much does this service usually run? THanks
SHOtimer
#2910
Santa Clarita, Ca
The SHO has the same suspension as the other 10 million Tauri that were built. Any alignment shop shouldn't have a problem. I'd expect anywhere from $50-$100.
Doug
NJSHO
Clean Your Shorts!
NJ
It depends on how well you want the alignment done. Any shop can do it, but most will only get you in a certain range instead of dead on.
michaelcz
TT SHO
Albuquerque, NM
I got my alignment today, but when I turn there's a popping noise on the front right tire. Does anyone know what this might be? It wasnt there before. THanks
stangeater
Farm Boy
Popping is probably from your strut. If they straightened up the camber alignment, it changes the angle of the strut, and if yours are worn, that could be what the pop is comming from.
I just had the tow in and camber aligned on my car by firestone and it cost me $84.
