Alignment needed when swapping brakes?
TwiceSHOwn
Atlanta, Ga
When installing 96 brakes (spindle swap on a 93 back) is an alignment necessary? I have heard it both ways.
S
slosho
Guest
Yes, since you are basically disasembling the front suspension. Especially if you are disconnecting the tie rods.
95' ATX Silver Frost
Cone Filter W/ heat shield
TB coolant Bypass
Bypassed a few "PCV" line
Lighting mods
Sony head unit (el cheapo cdx-650)
JL Monoblock 500
JL 2-12w3's
Rear tint
More to come.
SHOnOFF
Voorhees, NJ
What about after doing it on a 94/95? No spindle or knuckle replacement necessary there. Just the caliper bracket, rotors, and pads.
Brian
'94 Green ATX
5%/13% Tint
Coneless/Boxless
Valve Lash Adjustment - Finally! (8/18)
Blazer driving lights
96 Brake Upgrade
24/26mm sway bars waiting to go in (need bushings)
S
slosho
Guest
It isn't necesary if you are JUST doing brake work.
TB coolant Bypass
Lighting mods
JL Monoblock 500
JL 2-12w3's
Rear tint
More to come.
