SuperG
The alignment plates up front have the welds cut and I have eccentric busings in the rear. However, today, Firestone informed me that the best they can get on the alignment is:
Front maximum camber is -0.7 on the left and -4.0 on the right! They claim they cannot increase the negative camber on the left nor decrease the negative camber on the right...
Rear maximum camber is -2.4 on the left and -2.0 on the right. I wanted at least -3.0...
What on earth can prevent the camber from being limited? And let's assume the tech actually knows what he is doing.
I would appreciate any ideas. I will check the struts for bending, as suggested by the techv (but not checked by him). Can tie-rods, tension rods, or other components cause this?
BTW, toe is .02 in both front and rear and caster is 3.7 left and 3.9 right.
If I cannot resolve the alignment quickly...would you suggest I not drive the car until the camber problem is corrected?
Thanks for any help!
