airbag light code 42
smokin joe
Milwaukee WI
As the title says my sho flashes code 42 from the airbag light any suggestions would be great i tried disconecting the neg battery term. and reconecting the crash sensor under the plastic piece in the engine bay Thanks Joe
Wrong sensor.
This one's for the sensor at the cowl ( center of if at base of windshield.)
DTC 42: CENTER RADIATOR PRIMARY CRASH SENSOR FEED/RETURN OPEN
Normal Operation
The voltage at Pin 18 (Circuit 619, PK/W) is approximately 10 volts (± 1 volt). Circuit 619 is connected to Circuit 625 (Y/LG) inside center radiator primary crash sensor. Therefore, the voltage at Pin 6 should be the same as the voltage at Pin 18. If the voltage at Pin 6 is lower than the voltage at Pin 18, the air bag diagnostic monitor will flash code 42.
Possible Causes
Low voltage on Pin 6 can be caused by:
(1) An open circuit in the wiring harness in either Circuit 619 (PK/W) or Circuit 625 (Y/LG).
(2) An open circuit in center radiator primary crash sensor across the PK/W and Y/LG wires.
Make certain you remove battery power before messing with it.
Minnesho
i was wrong
MinneSHOta
smokin joe said:
yeah thats the one i tryed center radiator
read the post above, its for the one in the CENTER COWL. NOT the one near the radiator. Its near the windsheld.:smash:
Oops!!
OOPS!!
Looks like I posted the wrong info above combined with the correct info.
Use the part that I copied fromnt he service CD ands not the reference to the cowl location.
Sorry for confusing them....
