Airbag code 32
vortex2450
Buying Parts...
North Carolina
I've finally tamed my CE light but the I'm still getting an air bag code.
It's code #32 which SHOtimes references as "Driver-Side Air Bag Circuit - High Resistance or Open "
The steering wheel was updated from the 92' style to the 93' style by the PO and I've had this code eve since I've taken ownership of the car. Is this just a connecter not plugged in or what?
Or is the 92' harness incompatible with the 93' wheel?
And if not how should I tackle fixing this issue? Disconnect power, disassemble steering wheel and look for dangling connector?
I found this diagram through a search:
http://jonheese.com/SHO/airbag-diagram.pdf
Anyone want to point out where my issue is?
Thanks,
Josh
kevinspann
Don't take my advice.
Richmond VA
Pull the airbag out and see if it's plugged in. The plug on the '93 air bag is different than the '92.
If you have the wrong plug, clip one off of a car at the JY and swap it onto the clock spring in the car.
