Center Radiator Primary Crash Sensor Feed/Return Circuit Open
Normal Operation
The voltage at Pin 18 (Circuit 619, PK/W) is approximately 10 volts (± 1 volt). Circuit 619 is connected to Circuit 625 (Y/LG) inside center radiator primary crash sensor. Therefore, the voltage at Pin 6 should be the same as the voltage at Pin 18. If the voltage at Pin 6 is lower than the voltage at Pin 18, the air bag diagnostic monitor will flash code 42.
Possible Causes
Low voltage on Pin 6 can be caused by:
An open circuit in the wiring harness in either Circuit 619 (PK/W) or Circuit 625 (Y/LG).
An open circuit in center radiator primary crash sensor across the PK/W and Y/LG wires.
Extreme caution should be exercised whenever dealing with the air bag restraint system.
Edit: More info.....
DEACTIVATE SYSTEM
Turn ignition switch to OFF.
Deactivate system.
Disconnect air bag diagnostic monitor.
With Rotunda Digital Multimeter 105-00050 or equivalent, measure resistance across Pin 18 (Circuit 619, PK/W) and Pin 6 (Circuit 625, Y/LG) of the air bag diagnostic monitor harness connector.
Is resistance reading less than two ohms?
If yes, replace air bag diagnostic monitor. Reconnect system and verify system. Reactivate system.
If no, check the resistance of the center radiator primary crash sensor
Disconnect center radiator primary crash sensor from harness.
Measure resistance across PK/W and Y/LG wires in sensor connector.
If yes, locate and service open circuit in the wiring harness between air bag diagnostic monitor and center radiator primary crash sensor in either Circuit 619 (PK/W) or 625 (Y/LG). Inspect all interconnections. Reconnect system. Verify system. Reactivate system.
If no, replace LH primary crash front air bag sensor and bracket. Reconnect system. Verify system. Reactivate system.
