aftermarket tach
NovaSS
Project MINIGUN
Is there any special needed to run an aftermarket tach off a sho electronics???? This is for a swapped car so the only electronics is the engine harness so I just can tap inot the old line:)
NovaSS
Project MINIGUN
i believe there is an option when ordering that says for use with distributorless systems. its called a tach adapter.
also wanted to ask if your doing an aftermarket speedo also?
edit: like dis
http://www.summitracing.com/parts/SUM-850511/
Ill be using an indash tac and speedo, the speedo will be electric driven from a sensor on the intermediate shaft.
Sho Amo
SmkTyresntDrugs
Olney, Md
i always wondered how people used aftermarket speedos. thats kool.
