Hehe...with Sergio driving it...I can believe it!
I'm pretty sure there's not many, if any, active members here on shoforum that can ride balls out in corners like Sergio! And to add, I don't autocross. But I'd think autocrossing many times with a stock diff, or any diff for that matter, would heat up the fluid pretty bad to maybe break it down if it's not equipped with a trans cooler. And therefor causing excessive friction to cause galling.
Edit: For whoever asked about how to solve the roll pin walking out case, simply replace it with a larger one. I believe the stock one is 4.5mm. I replaced mine with 3/16" and pretty much had to use more force to put it in. I bought three for all three roll pins in the diff...size 3/16" X 1-1/2". For .25 cents a piece, you can't beat it! I also bought a roll pin for the shift lever shaft for an extra .30 cents...3/16" X 1". There's more roll pins inside the trans like on the shift fork shafts, but I didn't fill like replacing all of them, but if you want they're like 3/16" X 1" too.
<small>[ December 13, 2003, 09:33 PM: Message edited by: TYSHO ]</small>
