afr with x4 and tune
slowsho04
georgia
Installed my unleashed 3 bar tune today. All I can say is wow. Car runs damn good. Have a few questions tho. Was trying to warch the afr and didn't know wich gauge was the correct one. I was using bank 1&2 and afr was staying around 14.5 idle aND 13.5 -14.5 wot. Seemed off to me. No valve rattle,and car ran fine. What are you guus seeing/using?
Are you using the SCT device to monitor or Torque or ...
In the datalogs, you will see measured afr 1 and measured afr 2. Is that what you are referring to? You must not be going full/prolonged WOT if the afr only drops to 13.5, OR the tune is not aggressive. 87/91/93? Plugs gapped to 0.028/0.030?
slowsho04
georgia
Unleashed 93 3 bar tune. And yes full wot 0-80. Afr log is on the sct x4. Using bank 1&2
more than likely it is too large to attach directly to a post on this forum, so you would have to put it in a public Dropbox folder or a Google Drive folder and post the link to the file here.
