adidas_kn
LOWSHO
Trying to keep the interior simple and the gauge array to a minimum. So I come across the new AEM Tru Boost and here is what I find. This will probably be the best alternative to the Mucho Expensivo TurboSmart E-Boost 2($470).
Features:
* Create your own gauge style! Includes black and silver bezels and pin guides, and black and white face plates so you can personalize the look of your gauge.
* Fits a standard 2-1/16" POD!
* Complete stand-alone boost controller gauge
* On-board pressure sensor included for boost levels up to 29 PSI. (For boost levels over 29 PSI order the optional external boost sensor, good for up to 75 PSI)
* Peak boost memory
* User selectable over boost alarm with over-boost shutdown
* User scalable bar graph display
* User selectable waste gate delay for quick turbo spool
* External warning lamp driver
* No external interface required for programming
* Displays vacuum. (It is displayed as "negative PSI" without a negative sign, vacuum is not displayed as "in. Hg".)
* Easy to install harness allows for quick and easy installation
* Boost hose and fittings included for easy hookup to on-board pressure sensor
This bad boy is only $265-$285. Not bad for an all-in-one type combo.
Oh and the mandatory link http://www.boostcontroller.com/index.php?item=355&ret=http%3A%2F%2Fwww.boostcontroller.com%2Findex.php%3Fpage%3D1%26category%3D155
Features:
* Peak boost memory
