JD,
On these boards you often hear of someone doing the recall and "spinning the top nut". I just replaced my front SFB's today and while I did not "spin the nut", I think I know how many people have done so.
The nut is held in place by a couple of metal tabs on the frame. After I removed the bolt, I was able to reach up and maneuver the nut out, WITHOUT adjusting the retaining tabs, by pushing up on the nut and turning it.
So... my guess is that many people might "spin their nuts" if, when unscrewing the main bolt, they hold the bolt flush against the SFB bushing washer. This means that the "nut" gets pushed up and possibly pushed out of its tabs.
So,,, what I did was to GENTLY unscrew the main bolt, and let the bolt "drop down" as I unscrewed it.
Note: The ORIGINAL "nut" is one of those cheap-o stamped things, so you can not simply put a socket on it to stop it. The recall units do have a real, live nut though.
By the way. When you pull up the carpet of your car, there had better be a 2.5" hole (with a rubber plug) underneath the clutch pedal, and another one in a similar location on the PAX side. If there isn't, then the dealer who says he did the recall is full of it.
