Advice Needed
excidere
lost
Oklahoma City, OK
About a month ago I happened upon a 1990 Taurus Sho sitting in a front yard, looking like it needed a home. No bumpers, wheels or side skirts, and 121k, upon talking to the owner I found out that it had been parked for the last 5 years due to the 'transmission going out' because his girlfriend did not know how to drive a stick. I got the car to my shop and discovered the linkage was broken at the base of the shifter, and it would turn over, but not start. When I began to tear into the motor for the 60k I discovered a hole the size of my fist burned through the air filter, obviously backfired. Now my questions are..
1) What things besides the 60k should I service as a result of the long sitting time.
2) Does a backfire damage any of the sensors?
3) I have a good mechanical background (I'm an automotive sunroof installer) and have done all the work on my current tauruses. Could I adjust the valve lash and replace the shims safetly? Is there a guide other than shotimes's?
4) Is it possible to get a rod shifter from a later model sho and modify it to fit, or do I need a kit?
Thankyou...
Denny
Taurus Homeland
Atlanta, GA
Brakes, suspension, body/rust/clearcoat peeling, fuel pump, tranny, just to start. Interior would probably use a good cleaning too, check for any living or dead inhabitants
Sorry can't answer this one
Yup, www.shophoenixproject.com has the best 60K guide out there on the net, kudos to Joshua :thumb:
Yes, you can find them off of any 91-95 MTX SHO. Just make sure you get all the brackets from under the body. You'll need to replace your exhaust center pipe, easy one here, get a new catback system
http://www.shotimes.com/php-bin/mod...e=article&mode=thread&order=0&thold=0&sid=172
excidere said:
Thankyou...
You're welcome :)
