Adjusting Belts
SHOrus
For SHO
Two Harbors (Duluth), MN
I need to tighten the two serp. belts on my car. I haven't checked it out much, but I figured I'd make it easy on myself and post up asking how it's done. Thanks for any info.
93MTXSHO_STUD
lubbock, TX
My personal preference is to loosen the nuts for the pulleys to relieve tension (around 15mm wrench). Then I pull up on the pulls and hand tighten the metric hex nut until I cant anymore. Then I get a small stubby hex and tighten it several revolutions and then tighten the pulley. Thats the easiest way I've found to tighten these bad boys. I have to repack those noisy pulley bearing frequently.
93rev2sev
Hockeytown
If you are wondering "is it tight enough?", you should barely be able to twist the belt 90 degrees over a 1-foot span with 2 fingers.
