Adjustable front Caster?
FAST4DR
Check out this front locating link I found on this website for the 89-95 taurus.Ingalls I didn't know anybody even made anything like this. I thought you adjusted front caster by moving the subframe. Interesting. Any thoughts?
Will
nc89sho
S13 Sellout
Clemmons NC
josh at shonut performance sells those also, seems like a good idea, adjustability is always good
Shuey
MidWest
so where does that install or what does it replace? is this the rod that connects the subframe to spindle?
The caster is adjusted by moving the top of the strut fore and aft (usually aft) after the spot welds are drilled out in the upper alignment plate. The subframe should be centered with the provided alignment holes in the subframe and unit body, but the subframe can be relocated to correct for uneven camber from side-to-side. The SF in my car is moved laterally to allow the camber on both sides to be within spec.
The device in the link looks like a non-straight, adjustable strut rod. That rod is mounted between the spindle and the subframe at an angle. Adjusting its length would affect not only the caster, but the camber and toe-in too. Not a real good idea since there are better methods available to adjust the caster.
