adjust the timing?
Dr_Thompson
CT
Ive determined that the whine im hearing is comming from the timing belt. I just recently had it done, and ive heard of new timing belts whineing for a bit after install. Im gonna give it a while and see if it goes away.However is it possiable its to tight, if so how would i adjust the tension?
AREA 91
PA SHO SHOP
Area 91
The timing belt tensioner on all MTX cars is manually set by the installer. You slightly pre load the timing belt, and tighten the lock nut. You will see on the timing belt cover, that there is a small acess door that allows you to adjust the tensioner. :thumb: If you are hearing a "whirring" sound, it could be the tensioner bearings.
Racer X
SHO Pilot, Retired
Connecticut
When the tensioner bearings shit the bed, it is most definitely NOT a whirring noise. Ask me how I know. :frown:
My money is on your tensioner being too tight. Working from the passenger wheel well with the splash guard removed, look up and find the tensioner access hole. Loosen the nut, and with a 5mm allen key, slightly apply tension against the belt, and tighten the bolt again. Start 'er up and see if the noise is still there. Either it'll be gone, or greatly reduced.
Dr_Thompson
CT
Is the tension nut right below the water pump pulley and has a tab sticking out next to it?Where in relation is the hex key hole?Cant really see to much in there
Dr_Thompson
CT
ok, i got the inspection cover off. I see the 14 mm nut, wheres the 5mm hex key hole?
Dr_Thompson
CT
allright cool,i found it. Now its makeing a squealing noise, so im assuming its to tight. So does this mean i wanna loosen the 14mm, then go counterclock wise the the hex?How much should i loosen the hex?
Dr_Thompson
CT
haha, well loosened it to much. started it up, sounded horriable. tightened up, still sounded horriable.probably came out of time.niceeeee
