ACDelco Police Strut Mount
jthod
Mr. Goodwrench
Lincoln, Nebraska
I just ordered Eibachs, and I'm buying Monroe SenseTracs for the '90.
I'm looking around for Strut mounts and find this:
ACDELCO Part # 50134 {SUSPENSION MOUNT #88946268}
MOUNT,Front Suspension STRUT POLICE & SHO, SUSP MOUNT
Choose: [Regular Inventory -- Full Mfr. Warranty] ($34.79)[Wholesaler Closeout -- 30 Day Warranty (Only 9 Remaining)] ($21.79)
$21.79
ACDELCO Part # 50187 {SUSPENSION MOUNT #88946321}
MOUNT,Rear Suspension STRUT w/POLICE
$29.79
(Rock Auto)
I'm assuming this is the replacement to the discontinued Ford part???
If so, these should be a good replacement correct?
jthod
Mr. Goodwrench
Lincoln, Nebraska
1990 FORD TAURUS SHO 3.0L 182cid V6 MFI (Y) : Suspension : Strut Mount Price Core Total
ACDELCO Part # 501242 {SUSPENSION MOUNT #88946476}
MOUNT,Rear Suspension STRUT STA WAG
Choose: [Wholesaler Closeout -- 30 Day Warranty (Only 4 Remaining)] ($7.21)[Regular Inventory -- Full Mfr. Warranty] ($11.49) *
* Non-stock item--shipping delayed up to 12 business days
$11.49 $0.00 $11.49
ACDELCO Part # 501251 {SUSPENSION MOUNT #88946485}
MOUNT,Rear Suspension STRUT SEDAN, UPPER SPRING SEAT
Choose: [Regular Inventory -- Full Mfr. Warranty] ($14.30)[Wholesaler Closeout -- 30 Day Warranty (Only 2 Remaining)] ($8.97)
$8.97 $0.00 $8.97
ACDELCO Part # 50113 {SUSPENSION MOUNT #88946247}
BEARING,Front Suspension STRUT MT SUSP BEARING
Choose: [Regular Inventory -- Full Mfr. Warranty] ($14.84)[Wholesaler Closeout -- 30 Day Warranty (Only 7 Remaining)] ($9.31)
$9.31 $0.00 $9.31
ACDELCO Part # 45G25053 {#88913251}
MOUNT KIT,Front Suspension STRUT -; TO SPINDLE; 4 DR
$9.32 $0.00 $9.32
ACDELCO Part # 45G25052 {#88913250}
MOUNT KIT,Front Suspension STRUT -; TO FRAME
$11.19
MONROE Part # 901902 {STRUT BEARING}
FRONT; ; Sedan & Station Wagon
Choose: [Regular Inventory -- Full Mfr. Warranty] ($13.09)[Wholesaler Closeout -- 30 Day Warranty (Only 5 Remaining)] ($11.68) -^
^ Ships from same location as parts in cart
- Stocked in outlying warehouse--shipping delayed up to 1 business day
$11.68
MONROE Part # 903967 {STRUT-MATE BEARING PLATE}
FRONT; ; Sedan & Station Wagon; Upper Spring Seat
$11.90
SPICER/RAYBESTOS Part # 5201011 {Professional Grade}
Front
$12.59
ACDELCO Part # 501270 {SUSPENSION MOUNT #88946504}
MOUNT,Front Suspension STRUT UPPER SPRING SEAT
Choose: [Regular Inventory -- Full Mfr. Warranty] ($21.79)[Wholesaler Closeout -- 30 Day Warranty (Only 1 Remaining)] ($13.38)
$13.38
KYB Part # SM5005 {Suspension Strut Bearing}
for SM5038
$14.32
ACDELCO Part # 50120 {SUSPENSION MOUNT #88946254}
Choose: [Regular Inventory -- Full Mfr. Warranty] ($28.79)[Wholesaler Closeout -- 30 Day Warranty (Only 8 Remaining)] ($17.61)
$17.61
$21.79
SPICER/RAYBESTOS Part # 5201050 {Professional Grade}
Rear; SHO
$23.79
MONROE Part # 901954 {STRUT-MATE BEARING PLATE}
REAR; Sedan
$23.79
MONROE Part # 901926 {STRUT-MATE BEARING PLATE}
FRONT; ; Sedan & Station Wagon; 901902 Bearing is available when only the bearing needs to be replaced.
Choose: [Regular Inventory -- Full Mfr. Warranty] ($26.79)[Wholesaler Closeout -- 30 Day Warranty ] ($23.79) -^
$23.79
DORMAN Part # 665002 {One per Pkg. Front Bearing}
Front Left
Front Right
Front Left Hand & Right Hand [Wholesaler Closeout -- 30 Day Warranty (Only 2 Remaining)]
$23.89
DORMAN Part # 665304
Front Left Hand & Right Hand [Wholesaler Closeout -- 30 Day Warranty (Only 1 Remaining)]
$23.89
KYB Part # SM5038 {Suspension Strut Mount}
Wagon; KIT; Front
Sedan; KIT; Front
$24.79
SPICER/RAYBESTOS Part # 5201043 {Professional Grade}
Front; Bearing Not Included; Contains Spacer
$24.79
KYB Part # SM5015 {Suspension Strut Mount}
Sedan; Rear
$25.79
SPICER/RAYBESTOS Part # 5201190 {Professional Grade}
Front; Contains Bearing
$26.79
$29.79
MOOG Part # K8630
Front Suspension; Upper; Incl. bearing
$45.79
MOOG Part # K8821
Front Suspension; Upper; Plate Kit; Adjustable; adjustment range from -1-1/4 to +1-1/4 Deg.
$47.99
SACHS Part # 802705
Rear; All (Exc. Station Wagon)
* Non-stock item--shipping delayed up to 2 business days
$24.79
KYB Part # SM5271 {Suspension Strut Mounting Kit}
Sedan; Front
Wagon; Front
$39.79
SACHS Part # 802712
Front; All (Exc. Station Wagon); Strut Mount and Bearing
$44.79
KYB Part # SM5272 {Suspension Strut Mount}
Sedan; Front
Wagon; Front
$45.99
:nut:
There's Rock auto full run down.
with Eibachs and Monroes, is there any need or reason for adjustable mounts?
:salute:
Mr Anonymous
Tire Wall
"Police" notations on 95% of Ford replacement parts meant nothing except for "sprayed with blue paint".
jthod
Mr. Goodwrench
Lincoln, Nebraska
OK, let's put it this way, if you were buying Eibachs and Manroes, what strut mount would you go with. Or, if you have Eibachs and Monroe, what do you have for mounts?
Mr Anonymous
Tire Wall
The cheapest ones you can find.
They're all the same.
CplPflummUSMC
Dover,Delaware
I know this thread is a year old and my question will probally more than redundant, but I just bought SHO2SEEs 1994 and with his suspension mods I would like to get a good replacment mount as his have gone the way of the dinosaurs. At advanced auto they have MOOG mounts that look beefier than the monroe mounts, but they are about 6x more expensive per strut mount. Is this worth it or are the monroe mounts the way to go? sorry for being a pain, but I don't want to put sub par mounts in and be back in the same spot in 6 months. Thank you for your time and help. Semper Fi!!
93rev2sev
Hockeytown
Some rear mounts are rubber coated, cheap ones are just powder coated stamped steel---makes no difference, really. Front mounts are almost all the same.
If you have the choice, I say get the mounts made in the USA.
carry on!
