Im changing both my accessory belts, but without doing a 60k (which iv never done anyways). I beleive I have found all this steps. Please tell me If im missing anything or if anything veries. Thanks. One a 95 MTX.
Remove the battery and tray.
Remove the engine dampener thinymajig and bracket
Loosen that allen screw belt tensioner on the front and remove belt
Loosen the tensioner on the rear belt. (This is the nut above the rear tension pully?)
Then pull off the rear belt.
Assembly is reverse.
Anything else or helpful hints?
Thanks, Mike
Thanks, Mike
